I have a feature line in my drawing. It is one of over 1000 breaklines in a surface. I want to delete it from the surface but keep it in the drawing. How do I do this?
In 2009 this was easy. I could erase the featue line then use the OOPS command to get it back in the drawing. Unlike the UNDO command, OOPS did not put it back in the surface definition. This was a wonderful feature/bug. In 2012 OOPS behaves the same as UNDO.
I found this post regarding finding a breakline in the surface definition but that is not realistic with 1000 breaklines.
Here are a few options I have tried:
Anyone have any other ideas?
Solved by JeffPaulsen. Go to Solution.
LIST the featureline. AT the end of the Listing will be the Breakline info for it....Surface, and either the name you gave it or the name autogenerated. This should allow you to quickly find it in the surface breaklines.
Elevation : 111.900'
Grade : 0.00%
Breakline Data : Phase1-FG, Breakline set3: 3
I have not seen oops behave like undo in 2012. I still delete breaklines that way.
John Mayo
There needs to be a way to remove featurelines from a surface via graphical selection sets. Let's make some wishes folks.
"OOPS"=UNDO
I would check your settings. I just deleted 5 breaks with erase. Brought them back into the file with oops and they did not go back into the surface definition. I have been doing this daily for about a month since we moved up.
John Mayo
Messages 2 and 3 above are both solutions to the problem.
Per Jeff_m:
If the breakline is a feature line you can LIST the feature line and determine the breakline set and number and delete it from the definition.
Per John M:
The OOPS command works the same as it did in 2009. You can erase the breakline and bring it back with the OOPS command.
The OOPS command is working for me now. It was not two days ago. I even verified it with a coworker who saw it being added back into the surface to make sure I wasn't seeing things.
Yes, I could copy and paste it but that is very slow on my computer and I would still have to move it to the correct site.
Erase and Oops is the way to go. I can't explain why it wasn't working for the other day. I just hope it continues to work.
So per Allen Jessup's post last week, is OOPS a solution or a workaround?
What might the C3D help file say on this "solution" if it were to be documented?
This question is from longe time ago. I just reply for those have the same problem.
You can:
1- copy those breaklines into clipboard by Copy With Base Point command (Ctrl+Shift+C)
2- then delete the breaklines from drawing with AutoCAD command which removes them from surface.
3- then paste the copied objects into drawing (Ctrl+V) it asks for base point, select the same bease point selected for copy.
4- these pasted objects are not breakline.
Shahrokh
SNC-Lavalin Inc.
Toronto, Canada
