Hey all,
I am making a custom sheet set for my 100+ page Project and I was looking for some basic help.
The Question:
How do I set up an insertable field on a sheet that will post a value the is equalt to either a page higher or a page lower (i need both).
Where I think to go:
I open my sheet set -> Propoerties -> Edit custom Properties" -> Add ...
I name the style "Sheet -1" (will also do +1)
It the asks for a default value, and I want the default value to be set to -1 of the current page. HOw do I accomplish this? It will literally save me tons of mundane work.
Thank you and I will supply additional information / pictures if needed.
-ZAKATAK
Copy to formula AutoCAD uses to denote SheetNumber: %<\AcSm Sheet.Number>%
Now, when you create the new field, tell it you're inserting a formula. In the formula, paste the copied code for SheetNumber. It will evalualte to the current sheet number. Put a -1 after it and press evaluate. It will update to show the sheet number minus one.
Best regards,
Tim
