I have a normal line that goes throw a 3D faces which i want to find the point that these 2 objects meet, what i mean is likei want to know how long is it from one end of this line is to that point where the lines cross the 3d faces.. if someone understand what i mean??
The white are in my picture is 3D faces and he red is my line
One way:
Am not sure i f i understand what you mean but my line is 3d line and when i _flatten the objects it all became 2d in one level, the whole selected 3d parts became 2d " flattened" ... if you know what i mean ... and even if i finish to step 2 and 3 .. nothing really happines
If you apply a grading to the line that targets the surface, any place where it transitions from cut to fill is a point where it passes through a face.
Am kinda new to the whole Civil 3d world so maybe you guys understand me and am just not getting it .. or you are not understanding what i mean.
I am sending a video of what i am trying to do.
i made a surface from my 3d faces and now i want to find the place where the 3dpolyline tangent the surface
https://screencast.autodesk.com/Main/Details/7faa3878-f737-4db7-9c63-87d093016e9
I think I understand what you are asking for. Perhaps you don't understand the concept of using a grading to solve it. Please view this screen recording. It shows a featureline that is passing through some TIN triangles. There is a grading applied to it which targets the surface. Areas in red are below the surface, areas in yellow are above. The points where the grading crosses from cut to fill are where the featureline intersects the triangles. You can use the grading as a guide to break the featureline at the points of intersection.
http://screencast.com/t/BLwJob2wI4C6
Try this. Trace the face of the 3dface with a polyline using end snap or near snap. Click on the polyline and drop the elevation to zero. Trim and extend at will.
