Hay all
I need an urgent help, how can I draw underground ductbanks using civil 3D. the attached pdf file shows an example of what I need.
You may have a few options. Part Builder to use Civil Pipe Networks, Subassably Composer to use a Civil Corridor or use AutoCAD 3D solid sweeps.
Mike
Duct bank = pipe network.
you have options to draw rectangular, round and elliptical pipes.
Joe Bouza
I've been doing underground electrical duct bank deisigns like this for the past 2 years now. Pipe networks will not work for this application , if you need to show the duct banks with a vertical curve in the profile. Pipes don't bend (with a radius) vertically. I do use pipe networks for the manhole structures & corridor for the the duct banks. It get tricky when when a 6-way ductbank spits off with a 2-way and joins back with a 4-way. Sometimes it easier to just draw in the duct bank "by hand".
good luck,
Paul
Joe Bouza
I do what Joe does but if I need an object for Navisworks for clash detection, I also extrude the ductback shape along the extracted vertical profile.
I guess. I'll stick with the profiles
Joe Bouza
Here is an exerpt from this post:
We can utilize a grading and the ability to project a feature line to a profile to create a pipe in profile that remains dynamic to any profile.
Here is the concept:
1) Create alignments from the pipe runs
2) For pipes that follow existing terrain, sample the existing ground surface. For graded pipes, layout a design profile for the pipe run.
3) Create a featureline from the alignment and apply the EG or Design profile
4) Create a grading from the feature line with near vertical slope using the relative elevation option. Set the relative elevation to be the depth of cover to the top of the pipe. For power lines the relative elevation can be in the positive direction.
5) Create another grading from the previous to represent the diameter of the pipe, ie. relative elevation =minus .667 for an 8 in. pipe.
6) Project the feature lines from the 2 gradings to the profile to get dynamic profiles of the pipe. In cases where the diameter varies, apply appropriate relative offsets along the grading for each pipe size.
Here is a screen recording showing the dynamic relationship.
http://screencast.com/t/NzIxOGQzZDM
I'm with you HCG.. I would have to use a layout profile with Neils procedure. There are too many underground utilitiies I have to weave over & under.
Paul
mine uses a surface profile
Joe Bouza
But it is not fulfilling my requirement, any way to shoe the pipes inside the ducts and clashes. (please see Detail-1,2,3) in the attached pdf) One more doubt about the giving elevations on the future line, I draw a future line and give the elevations in the vertexes, the I went to the elevation editor I wondered the elevations are no relations with the given elevations, I tried two three times but the result is same. What happening there? Any idea?
I usually project the proposed grade from the profile onto the layout then explode that line. I'll then extrude the ductbank section along that line. I know it's not dynamic and I'll have to re-project the line if a change is made but it's not that time consuming. I usually export the ductbanks for Navisworks.
