I think it can't be possible ? (I dont see the way ....)
I have my surface, I'm seeing it in orbit view mode . (also it doesn't work on 2D...)
I'd like to create a 3d Poly using some points on the triangles of my surface....
I'd need a transparent Inquiry tool , to use when I create points or 3dpols
I think it is basic....
I know _AeccFeatureElevsFromSurf
but i'm talking about a 3d Snap....
Any idea would be appreciated , thanks.
Civil 3D (2013) how much you have to improve....
if you have your OSNAPZ set to zero, you can set your surface to display triangles, start the 3DPOLY command, and then use object snaps to snap to your points of interest. does that help you in any way?
mmm nothing ocurs.
Thanks.
If you want to snap to the triangles lines, not the faces, you should use the previous suggestion.
If you have to snap to the faces, you need to set current a surface style that shows the Slopes. Explode twice and then use CONVTOSURFACE to convert from the resultant 3D solids to 3D Faces. Once you do that, the 3DOsnap CenterofFace will work on individual faces.
I'm just curious, what's your reason for not wanting to create a feature line rather than a 3DPoly?
I agree, a transparent command that offered surface elevation would be nice.
Tim
3Dpoly simply are easier to draw and give somebody, isn't it?
Maybe this,a 3Dsurface -Snap for 2D and 3D, could be done by customization (program) ?
In addition, feature lines ask for a lot of information .... I only want to draw inf pure 3D !!
C3D has the ability of know the coordinates (Z ) behind the cursor (although only in 2D....)
SO I understand that it could be easy to program what I want.
Thanks.
Yes I know, but I want a simply tool (oh my god!)
In addition, fetaure line does not work on 3d view ....
