Civil 3D Forum
How can I change the selection style highlights same as in C3D 2015
4 REPLIES 4
dilsmails1
1144 Views, 4 Replies
Hay  In civil 3D 2015, how can I change the selection style highlights same as in C3D 2014. Because for me, it is feels looking to a florescent lamp. It make much irritation to my eyes. Anybody can help.C3D 2015 Selection.png
Dileep
4 REPLIES 4
neilyj666
in reply to: dilsmails1
I'm not sure that this new enhancement to the user experience can be turned off.......I may be wrong though....
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Check out GrantsPirate's answer over here
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Object-Selection-AutoCAD-2015/m-p/5076742/highl...
Specifically you might want to check the PRESELECTIONEFFECT system variable.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
I'm going to be checking out this variable....:)
dhenderhan
I like this feature myself, but is there a way to change the color that it changes to?  Everything works pretty good unless I select something blue (150 actually, which we use quite a bit for drainages), then I can't tell if it's selected.
David E. Henderhan, PLS
Civil 3D 2023
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
Rail Community
