Civil 3D Forum
How c3d resolve superelevation overlaps?
4 REPLIES 4
tonnot
2438 Views, 4 Replies
I'm a little surprised with this....
I dont imagine how c3d does this .
Any idea ? Thanks.
Civil 3D (2013) how much you have to improve....
4 REPLIES 4
Joe-Bouza
in reply to: tonnot
When you say resolve - does c3d have a command that says resolve? otherwise I would think the design has to be revised to avoid overlaps
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
tonnot
in reply to: Joe-Bouza
Like this ?
Joe-Bouza
in reply to: tonnot
from help:
Automatically Resolve Overlap
Select this check box to automatically detect overlap conditions and eliminate the overlapping stations. All transition stations                     between the End Full Superelevation station on the first curve and the Begin Full Superelevation on the second curve are removed,                     for compound or reverse situations. This option is only available when superelevation is applied to the whole alignment.
Note
When this option is selected, corrections are made on all overlap situations. To remove automatic overlap, clear the check                           box and recalculate superelevation.
I did an intentionally short alignment to see the difference and it appears to elliinate the transistion to normal crown when curves are close together leaving an adverse crown going into the second curve?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
wowaron2008
in reply to: tonnot
How about shoulder superelevation on such overlap resolving. (The sholder doesn't follow the lane)
Rail Community
