At a multileader when "automatically include landing" is set to "NO" or unchecked, then a small point (like that at the end of a dimension line) is inserted in the callout block, such as the circle, which then prints. This makes for less than clean drafting to say the least--is this normal? If so, (why?!), is there any way to NOT have those points print/show up??
OK, I am now seeing what you have described. I hadn't seen them because my leader attachment is normally to the CenterExtents, but changing this to Insertion Point allows the Definition Point to show. (Tested this in both 2012 & 2013). This definition point is supposed to be placed on the Defpoints player so it won't plot, just as they are for a typical dimension. However, it appears they are instead taking on the same properties as the parent MLeader.
I tried adding a Wipeout to the Circle block to hide the dot, but the block is placed 'under' the leader so the wipeout has no affect.
Sounds like a Wishlist/bug report is in order.
