I am using Civil 3D 2012, sp1. I need to create a label style that shows the horizontal delta angle of an alignment on the profile. I have tried using profile labels and band labels, but can't figure out a way to do it. I have tried reference text, but it doesn't have delta angle as an option. Currently the only way we can add the horizontal angle to a profile is manually and that leave room for error.
It works just fine with a band style. Not sure what you are seeing.
Thanks for the reply Brian, I was able to add labels to the band, but now I have found that what I really need is horizontal angles on the profile and I need to be able to use those angles in expressions, which is something that bands don't have. Any other ideas on adding the angles to the profile?
Give us a better explanation of what it is you are trying to accomplish and there may be a completely different route to take.
