Stupid Spell Check:
It was supposed to be "dreaded", not "treaded".
Don Reichle
"King Of Work-Arounds"
LDT3/CD3
IntelP4-2.4
1GB RAM
Intel 64MB
"Don Reichle" wrote in message
news:4811571@discussion.autodesk.com...
> Hey Chakri;
> The treaded tooltips are my biggest beef with C3D. When next I get to use
> it that's the first thing I'll turn off, to save on precious screen
> display area. Maybe after I acquire a second display monitor I'll think
> about turning them on again.
> Maybe is there were a way to control the radius of the objects found near
> the cursor to display for the tooltip...
> Don Reichle
> LDT3/CD3
> IntelP4-2.4
> 1GB RAM
> Intel 64MB
> "Chakravarthy Gavini" wrote in message
> news:4811438@discussion.autodesk.com...
>> Joao,
>> Too many ways to skin this cat! One another way is to right click on the
>> profile to select "edit profile..." and then click "Profile Layout
>> Parameters" button (4th from the end). Select any PVI to get all nuts and
>> bolts of this curve along with high/low point data. Advantages of this
>> method is (a) you will be able to see all other parameters such as sight
>> distances curve min radius etc... (b) you can not only see the data, but
>> can edit most of it too.
>> In principle all geometrical parameters of the design (be it alignment,
>> profiles, corridors, grading foot prints and mostly parcels) elements are
>> provided through geometry editor tools such as "grid editors" and entity
>> editors. I know that this is not same as in LDT - but looked at it as a
>> design PLUS inquiry tool of the geometry.
>> We understand that general inquiry commands about
>> station/offset/elevation values and list slope/depth commands etc... are
>> missing, as they are in LDT, but current procedure (as of R2006) is to
>> use tooltips - and in some cases labels.
>> Hope this answers your concerns
>> Chakri Gavini
>> Product Designer
>> Autodesk Inc
>> wrote in message news:4811135@discussion.autodesk.com...
>>>I don't believe that autodesk haven't this simple tools (like land/civil)
>>>to inquire in new civil3d2006.????
>>> How can I designer work without this kind of tools???
>>> Thanks
>>> Joao
