I have a user placing a hide boundary in a building foot print and a contour continues to go into the building. It only happens with contour smoothing on if it off it clips as expected, any ideas?
Your Name
Your Name
Go to the Surface Properties>Definition tab and try putting the "add boundary" operation in question at the bottom of the list.
Your Name
Your Name
Your Name
Your Name
Annoying.
Using a mask works but does not carry through the DS
Your Name
Your Name
Mark Green
Working on Civil 3D in Canada
Your Name
Your Name
Mark Green
Try smoothing the surface, instead of the contours. You will get better looking results, and the contours will stay within the boundary.
Your Name
Your Name
It looks like you have your Smoothing Type set to Spline Curve instead of Add Vertices
Your Name
Your Name
I'd probably just cover them with a wipeout and be done with it.
Allen
Allen Jessup
CAD Manager - Designer
