AutoCAD Civil 3D General
Active Member
Message 1 of 3 (143 Views)
Help with assembly
143 Views, 2 Replies
04-07-2011 05:32 AM
Hello - I've attached a pdf showing a corridor section that I'm trying to work thru. The problem is with the subassembly shown at the left side. That left part of the assembly has the subassembly called "Link Slope To Surface" with a minus 6:1 slope.
 It is targeted to link to the surface shown. How do I get it to slope DOWN and link to the surface, and not UP to the surface
 like it is doing? It seems to want to link to the nearest point on the surface, even though the subassembly itself contains a (minus) slope. The red line showing the proposed 6:1 slope down is just a dumb line inserted to show what I'm looking for. Any help would be appreciated!
Steve Blackburn
Frost Engineering and Consulting Co.
*Expert Elite*
KMercier_C3D
Message 2 of 3 (133 Views)
Re: Help with assembly
04-07-2011 05:53 AM in reply to: frost_Revitup
Maybe the advice in this post will help you: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Generic-Link-Slope-to-surface-subassembly/td-p/286543...
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Active Member
Message 3 of 3 (111 Views)
04-07-2011 07:12 AM in reply to: frost_Revitup
Thanks! That was the solution.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
