Civil 3D Forum
Help with assembly
2 REPLIES 2
241 Views, 2 Replies
Help with assembly
Hello - I've attached a pdf showing a corridor section that I'm trying to work thru. The problem is with the subassembly shown at the left side. That left part of the assembly has the subassembly called "Link Slope To Surface" with a minus 6:1 slope.
 It is targeted to link to the surface shown. How do I get it to slope DOWN and link to the surface, and not UP to the surface
 like it is doing? It seems to want to link to the nearest point on the surface, even though the subassembly itself contains a (minus) slope. The red line showing the proposed 6:1 slope down is just a dumb line inserted to show what I'm looking for. Any help would be appreciated!
Steve Blackburn
Frost Engineering and Consulting Co.
2 REPLIES 2
KMercier_C3D
Maybe the advice in this post will help you: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Generic-Link-Slope-to-surface-subassembly/td-p/286543...
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Thanks! That was the solution.
Rail Community
