Hello all....can someone please enlighten me as to how I can put the above mentioned Sub-Assemblies in a CUT condition? They all default to a Fill condition (Attachment Point at Top of Wall). I need it to have the attachement point at the Bottom of wall. I cannot seem to find where to do this?
Thanks in advance,
The subassemblies will (or should) automatically switch connection points depending on cut/fill. Only one is shown during layout mode so it may be confusing. I posted an example demonstrating this some time ago. I will see if I can locate it...
See if this link helps:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Retaining-Wall-Subassembly/m-p/2903664#M145234
