Civil 3D Forum
Help, need to create a boundary around a mass of scattered points...
19 REPLIES 19
Message 1 of 20
3594 Views, 19 Replies
CIVIL3D 2012
I'm trying to create a boundary (either 2D or 3D polyline) around a group of random scattered cogo points.
The boundary or polyline vertices needs to be "attached" to, or at least sharing the same x,y,z coordinates as the points that create the perimeter of the group of scattered points.
The reason for this is to eliminate the lengthly tedeous process of creating a polyline and having to snap each consecutive vertice to the next point on the perimeter of a mass group of points (like 1000's of points).
I have looked into using the "Shrinkwrap" command, but it's not doing what I need.  It only seems to duplicate an existing polyline that surrounds the group of points, failing to attached to the points on the perimeter.
Please see attached pictures...
Thanks for any help that can be provided...
John
19 REPLIES 19
Message 2 of 20
Alfred.NESWADBA
if you create a suface based on these points, set the style to show the border, then extract the border of the surface ==> will result in a polyline (would be a 2min way).
If that's what you look for, ok; if not ... what is the rule to make it better? With "rule" I mean what would be your strategy to get a (for you) better result?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 20
in reply to: Alfred.NESWADBA
Alfred, thanks for your prompt reply!
Basically that's exactly what I would like, without having to create the surface.  Possibly a .lsp routine or something to that effect...
John
Message 4 of 20
mikesmi
Out of curiosity why don't you want to create a surface?  Is it extremely large?
Michael D Smith
Autodesk Application Specialist
Cansel - Autodesk Division
"Improving field to finish productivity"
www.cansel.ca
Increase your productivity with one of our Upcoming Training Events…
Message 5 of 20
in reply to: mikesmi
I'm looking for the most efficient route possible.  I realize that creating a surface, extracting the boundary and then editing it to fit to my preference is significantly more efficient than tracing the outline perimeter of a mass group of points.  But, I'm reallly just looking to invoke a command that will allow me to select a group of points and have a perimeter boundary created.
Message 6 of 20
neilyj666
If you are determined not to use the surface method then the easiest manual method is probably to set OSMODE to Node and OSNAPOVERRIDE to 1, this will only let you select the nodes but it could be a bit tedious.
Another way of approaching the surface method is to create the surface and then add a destructive boundary to delete spurious triangles.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 20
mathewkol
Basically there is no built in wlmethod to do what you need. So either you pay someone to create a tool for you (or someone here offers one for free) or you go to the next most efficient method...surface creation. Delete the surface after. Creating that surface is seconds worth of work.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 8 of 20
in reply to: mathewkol
its the editing of the boundary that i'm trying to avoid...the surface boundary works, but there is still plenty editing to do...I agree, it's better than the long manual way...but I need more efficiency...
Thanks to all who have responded, it's much appreciated...
John
Message 9 of 20
TerryDotson
If you were to consider third party software, we've just added Shrinkwrap Points to the MapWorks Points module.  Simply select the Civil3D points and it instantly generates a 3dPoly.
Message 10 of 20
mikesmi
Do you use the surface "delete line" command in conjuction with the CP (crossing poly window)  makes for very easy boundary editing.  See example pic where I are editing the boudary in one shot.  No selecting points just removing lines
procedure:
select surface
select edit surface
select delete line
type cp at the command line press enter
create funky shape around surface
enter to delete all lines touched
Michael D Smith
www.cansel.ca
Message 11 of 20
Alfred.NESWADBA
And that's why I mentioned  "what is the rule to make it better?"  It's an awesome job to get the rules defined, because you will always find situations where the border should use another connection as it did.
And to prove this theory look at this picture, is the blue or the red version the "correct border" (both based on the same point-locations)? I don't know it, how should a software check whats better and what not?
What I know: the version of Civil (with the option of max. triangle-edge-length) is quite good!
- alfred -
Alfred NESWADBA
Message 12 of 20
I'm not too sure what you mean by "rules"...
What I'd like to see:
initiate a command;
prompt to "pick a point" within the group (typically the user would click their curser or cross-hair in the middle of the grouping);
the routine then starts a polyline on the point furthest away from the "pick-point";
the next part of the routine would create a second vertice of the polyline on the next closest point to that vertice that is furthest away from the first "pick point";
continuing around the perimeter and finishing on the first vertice and closing the polyline...
...something to that effect...
Message 13 of 20
Alfred.NESWADBA
I meant a list of definitions for different situations that makes it possible for a developer to find through all situations to build the outline. And imho it's not possible to create definitions that work in every case (bad for a developer to have no regulation to follow).
>> What I'd like to see: initiate a command; [...]
I must admit that my english is not good enough to follow your description in detail (especially I don't understand the part with the second point, most far away from the start-point).
I showed two examples above, lets start at the lower left point. What would help me (or any other interested in algorythms) would be:
  • imagine you have a textlist (no graphical display) with x/y coordinates
  • search the point with minimum-x/minimum-y to get the start-point
  • ....and what are now your thoughts to find the next point that builds up the border (and does this concept work for any situation, for all next following points)
- alfred -
Alfred NESWADBA
Message 14 of 20
By no means am I a programmer, and with that being said I need to visualize the routine graphically...I don't know how to respond...
I really do appreciate your efforts tho...
Message 15 of 20
From Carlson Software:
"Shrinkwrap: introducing a Carlson feature, which creates a closed polyline, that encloses a given set of entities to be used in various other routines for inclusion or exclusion of entities."
if anyone has used this new feature, this is what I need in Civil3D 2012...
Message 16 of 20
mathewkol
Civil 3D has a shrinkwrap tool. It doesn't work with points. Does the Carlson tool?
I'm pretty sure we all know what you want. Point is, there is no tool for it in C3D. Terry offered his tool. Buy it if the surface suggestions do not suit your needs. (Assuming Terry's tool does).
Matt Kolberg
Message 17 of 20
TerryDotson
The question for Carlson would be "does it work inside Civil3D with AECC_POINTS?"
The routine worked fine on an approximation of the OP's capture, example attached.  It's based on a simple minimum turned angle logic.  If needed we could automate a triangulation (with maximum edge parameter) and extract the border.  What we don't believe in is jumping through hoops to get the results you need.
To the OP (original poster), request a full working 21-day eval and find out for yourselves.  I can be reached at dotson [at] dotsoft [dot] com.
Message 18 of 20
Thanks guys, for all your help.
OP
Message 19 of 20
rkmcswain
in reply to: TerryDotson
@TerryDotson - yeah, I know it's 12.5 years later, but is this shrinkwrap tool still available? I couldn't find it (searching for "Shrinkwrap" on this page: https://www.dotsoft.com/mapworks.htm )
R.K. McSwain     | CADpanacea | on twitter
Message 20 of 20
TerryDotson
in reply to: rkmcswain
@rkmcswain Yes, it's on the menu / ribbon as Points > Draw > Shrinkwrap.  I know of three approaches to it, so I'll look into adding the other methods (and to the web page).
Rail Community
