Civil 3D Forum
Help making a composite surface
18 REPLIES 18
Message 1 of 19
11140 Views, 18 Replies
I don't know why this is hapening, I've done this in the past and it worked out diferently.
I have an existing surface, I also created a second surface using feature lines and "grade to surface". Now I want to combine them and make a composite surface. So, I create a new surface, paste the existing surface and then the new proposed surface. The problem is when i do this they merge but the center of the existing surface dissapears.
See image for reference
How do i maintain the existing surface while still managing to add the proposed?
18 REPLIES 18
Message 2 of 19
just posting other pics here
Message 3 of 19
wfberry
Use the search feature of Civil 3D and search for "infill".
Bill
Message 4 of 19
in reply to: wfberry
I know about the infill function, but what I actually need is the existing surface within the proposed dikes to show up. right now it is just blank space. I could use the infill function if it comes down to it but it will give me inaccurate volume calculations (since it will be a flat, infilled surface)
Message 5 of 19
sjg
Turn on your borders in your surface style for the proposed surface, try adding a hide boundary on the inside of the proposed surface.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 6 of 19
in reply to: sjg
I just did this, and I am getting the same result. It clips out the middle (existing surface) even if i DONT have a hide boundary.
I've attached an image, the existing surface is shown in orange, the proposed dike in blue and the composite surface in green (which contains the proposed dike surface and the existing surface). as you can see the existing surface in the center of the dike does not get included when added to the composite surface.
Message 7 of 19
Hidden_Brain
if you are adding an outer boundary to your proposed dike surface and also a hide boundary in the middle, reorder in the surface build operation to have the hide boundary addition after (below in the list) the outer boundary addition, and see if that makes a difference.
Message 8 of 19
in reply to: Hidden_Brain
I'm not adding any boundaries for my surface, the hide boundary was proposed as a solution but it did not work so i removed it.
Message 9 of 19
troma
Try adding a show boundary for that middle portion.
Mark Green
Working on Civil 3D in Canada
Message 10 of 19
Hidden_Brain
interesting, i am seeing the same behavior as you are. even when i create a new blank surface, paste EG into it, then use the perimeter of the middle portion (toe of slope) as the outer boundary, and then paste that into the combined surface, i still cannot achieve desired results. with or without an infill on the FG, same deal.
sorry, not the answer you were probably looking for, hopefully someone wiser and more knowledgeable than I am will soon weigh in.
Message 11 of 19
Hidden_Brain
in reply to: troma
i cannot make the combo show EG in the middle using a show boundary. it appears the show boundary on the combo creates similar result as adding an infill.
Message 12 of 19
troma
Perhaps then the only workaround is to make a third surface. Paste EG in and add that toe of slope as an outer boundary. Then paste onto the composite.
Mark Green
Message 13 of 19
Hidden_Brain
in reply to: troma
i tried that too (please check my earlier post), same results. i cannot make it work at my end.
Message 14 of 19
troma
Sorry, missed that point.
Got me beat. I'm sure it's worked like one or more of these combinations for me.
The only other combination I can think of is to make a new surface and paste in the **** and then the centre surface. Then make your combination surface and paste in EG and then this '**** with centre' surface.
Mark Green
Message 15 of 19
lee
I've had the scenario before.  What I did is first make a copy of the existing surface. Took my finished grade surface and extracted the surface border.  Took the border and used it as an outer boundary for the existing surface copy.  Then for your composit surface, paste the original eg, finished surface and then the eg copy.
Lee
Message 16 of 19
Hidden_Brain
in reply to: lee
lee,
i think i did the steps that you are suggesting, with the only difference being that i created a blank surface and paster EG into it, instead of making a copy of the EG. I could not make it work with adding the outer border on the blank surface (pasted EG), and then finally pasting it into the combo in the following order: EG, FG, blank surface.
I can try making a copy of EG and repeating the same steps to see if it makes a difference.
Message 17 of 19
BrianHailey
Here's the approach I would take. If you did something similar without it working, post up your surfaces and we'll take a look at it.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 18 of 19
Joe-Bouza
take the bottom FL of the dike>> create a new surface EG-bottom on dike, use the FL to make an outer boundary to the Dike. Paste EG-bottom to the composite
Joe Bouza
Message 19 of 19
lee
What you do with the copy of the eg is use the (extracted) border of the FG surface as a outer boundary for the eg surface copy.  Thats the surface that will fill in the area you are wanting with eg contours.  Thats why when you are creating the composite surface you past it last.
Should work.  I know it works when I have your senario.
Lee
Rail Community
