AutoCAD Civil 3D General
jnichol83
Message 1 of 2 (198 Views)
HecRas Import Georefrencing Error
198 Views, 1 Replies
09-19-2012 07:20 AM
I'm new to exporting from AutoCad Civil3d 2011 to HecRas and I've run into a problem and not sure what the solution is. I export out my alignment, sample lines and surface data to a GEO file and when I try to import it into HecRas it gives me the error that not all my cross sections are georefrenced, its as though the samples lines past a certain point on my alignment aren't georeferenced (according to HeacRas) does anyone have any ideas what the problem is?
Active Member
cwgeary
Message 2 of 2 (192 Views)
Re: HecRas Import Georefrencing Error
09-19-2012 08:22 AM in reply to: jnichol83
I don't know if this will help, but I recently had to do that for a project and was getting a similar error when importing the *.geo file into HEC-RAS.  For me, it was that my cross sections extended past the limits of the TIN.
Good Luck,
Chris
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
