Civil 3D Forum
Headwall with double pipes
6 REPLIES 6
StevenBryant
2036 Views, 6 Replies
I have been unable to attach two pipes to a headwall.  Tried to make the headwall wide enough but each pipe still overlapped.  My current work around is to use two headwalls. Is there a way to get the double pipes with a single headwall?  or am I stuck with two headwalls.
6 REPLIES 6
Neilw_05
in reply to: StevenBryant
Try a forum search for "double pipe". There are several similar posts on this question.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
StevenBryant
in reply to: Neilw_05
Thanks for the quick reply.  Was able to find something that worked pretty well.  Simple yet effective.
Steven,
It's great that you found a solution.  Could you share what you found?
StevenBryant
david.dixon
This solution is a drafting workaround and does not create a true BIM model object. Can users expect added pipe/structure features in the future to support double/triple/quad barrel pipes into a single structure?  The solution looks odd in Navisworks too and doesn't work when importing/exporting using SSA.
David Dixon
Senior Civil Designer
hdrinc.com/follow-us
how could i drow double barrel attach to head wall
Tags (1)
Rail Community
