AutoCAD Civil 3D General Discussion
Ibarra10
Message 1 of 5 (129 Views)
Accepted Solution
Hatching Option In Profile View Properties
129 Views, 4 Replies
09-27-2013 07:29 AM
I am trying to show cut and fill hatching in the profile views but the hatching doesn't show up. I've tried changing the hatching styles, the scale, the colors, etc. but it doesn't seem to be working. Does anyone have a solution to this?
ken.sanderson
Message 2 of 5 (107 Views)
Re: Hatching Option In Profile View Properties
09-27-2013 10:18 AM in reply to: Ibarra10
just a couple quick checks
confirm you have profile picked when setting up the hatch, it defaults to plan view every time you access it
and confirm the layers setting are turned on in the layer manager, basic suggestions
otherwise sound like it should be working
Ibarra10
Message 3 of 5 (104 Views)
09-27-2013 10:21 AM in reply to: ken.sanderson
I had check those in the beginning and it still didn't work but i figured it out about an hour ago. I had to go into the profile view display properties because the profile view style i was using had the hatch component off.
ken.sanderson
Message 4 of 5 (102 Views)
09-27-2013 10:23 AM in reply to: Ibarra10
glad to hear
cheers
Ken
*Expert Elite*
BrianHailey
Message 5 of 5 (85 Views)
09-27-2013 03:39 PM in reply to: Ibarra10
You should mark your response to your thread as a solution so others searching for the same issue will see that there is a possible solution in this thread.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
