Is there a setting for hatch transparency? My work station it works fine. I have a few other users complining that is doesn't work. One user I imported my arg profile and it seemed to do the trick, but the next user I imported my arg and it had no effect.
Joe Bouza
Solved by Alfred.NESWADBA. Go to Solution.
Does it only happen for hatches or for other objects also (eg. polylines with width)?
Does it just not show on screen or also not when plotting (assuming the checkbox in the plotdialog for transparency is activated)
Has the entity the assignment of the transparency value or is it set to "byLayer" and the layer has it's transparency setting?
As you test with profiles I guess you have tried that this issue is not drawing-depending, so a drawing from that one system (where it does not show transparency) is doing well on your system.
And to be complete (for the moment) the button in the statusbar for transparency (or sysvar TRANSPARENCYDISPLAY) is on 😉
- alfred -
Joe Bouza
