unsivilaudio
Message 11 of 15 (319 Views)
Re: Ground to grid problem.
05-16-2012 08:05 AM in reply to: IanMcClain
Ian I agree.  There is no way for CAD to know to apply a scale factor from a simple csv file, but it is in fact doing it.  I know this by comparing northings and eastings of in CAD and what TBC is outputting to my csv file, in fact if I manually key in the correct northing and easting, the point will move onto my linework.
Anyways, thank you Sinc for the suggestions, no I had not set up a user settings db for the SDB.  It was only 1 setting in need of changing (Internation foot to US foot) so I didnt really feel the need.  However, in light of these problems, I have now and hope to avoid any further issues in the future by doing so.  We'll see.
Joel Jacobs
CADD Specialist
Western Land Services
1662 S. Sheridan Ave
Sheridan, Wyoming 82801
Valued Mentor
IanMcClain
Message 12 of 15 (318 Views)
05-16-2012 08:09 AM in reply to: unsivilaudio
Have all your Survey users path and select the SDB file and have your CAD manager set this in the deployment (I think that is possible?) This same issue comes up for my firm whenever we get a new surveyor or somebody gets an upgraded PC :smileyfrustrated:
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
unsivilaudio
Message 13 of 15 (295 Views)
05-17-2012 09:36 AM in reply to: IanMcClain
I figured it out!!!! :smileyhappy:
Thanks in part to re-reading Sinc's post.  Our drawings seem to be getting confused on the coordinate system; even though in the drawing settings they seem to be set correctly.
The Solution:
Set your drawing to "No Datum", hit "Apply" and then "OK".  Import some points with the SDB (not sure if this step is 100% necessary, but you will see they come in with no scaling, no correction). Set your drawing back to the correct coordinate system, and reimport your points (they should remain unchanged).
Joel Jacobs
CADD Specialist
Sinc
Message 14 of 15 (273 Views)
05-20-2012 08:27 PM in reply to: unsivilaudio
Typical protocol is not to select your "thank you" as the solution, but instead, select the post(s) that actually gave the solution...  That's the post that later users will look for.  And to quote Joe, "We're all in this together..."  If we're clearer with each other (and take advantage of some of these new forum features), the easier it makes it for others to learn this very-convoluted and often-confusing piece of software.
Sinc
unsivilaudio
Message 15 of 15 (267 Views)
05-21-2012 06:55 AM in reply to: Sinc
Well aware, however, you're post only led me to the solution.  I marked my own post as the solution because it IS the solution to my original problem.  Aparently even you didn't understand what my problem was.
Joel Jacobs
CADD Specialist
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
