hi all,
It seems like I used to be able to do this in 2012.
I created a design profile and used the copy profile command. I close the layout toolbar of the original design profile.
When i select the copied design profile to grip edit a pvi, the existing ground profile and copied profile disappears and i cannot grip edit.
I have also tested this with an OOTB template.
Question: Is anyone able to grip edit a copied design profile in 2012.
TIA,
Brent
I use the AutoCAD copy command for this and I can edit the copied profile this way. I tried it your way and I'm still able to.edit PVI's.
@Anonymous wrote:
hi all,
TIA,
Brent
Yes. There HAVE been times when I could not. I'm sure there is a thread on here about this, started by Sinc I believe. I don't recall what was found to trigger this, or what the fix was. Hav eyou exited teh drawing and reopened to see if you can then edit it?
Here's a link to that previous thread:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/C3D-2012-Can-t-grip-edit-Profiles/m-p/3160906#M160084
Jeff and Matt,
Thank you. I am still not possitive what is going on?
Anyway, an update;
1) Perform repair on the install
2) Turn Hardware acceleration on
Inside of Edit profile geometry copy profile and raise lower, then try to grip edit - same results
AutoCAD copy command - I can grip edit (did not work before the repair, btw).
I really don't know what is going on here, but at least I can move on, for now.
Again, thank you for your responses,
Brent
