How do I change the grid lines from solid to a dotted line in the Section View?
Solved by john.mckenzie. Go to Solution.
It is all about the style. i will try to be more specific in a moment. changing the linetype in the style for either the horizontal minor and or major gird lines and the vertical minor andor major grid lines is where to do this. You can assign these grid lines to layers and control it bylayer or you can just change the linetype that is used to draw them in the style your choice.
