AutoCAD Civil 3D General
Active Contributor
Wilbers2013
Message 1 of 4 (204 Views)
Grid at Vertical Geometry Point
204 Views, 3 Replies
10-09-2013 03:06 AM
Is it possible to have a profile view grid line at a Profile Vertical Geometry point?
___________________
Civil 3D 2011 & 2013
ArcGIS 10.1
Nik-D
Message 2 of 4 (185 Views)
Re: Grid at Vertical Geometry Point
10-09-2013 04:49 AM in reply to: Wilbers2013
I might be wrong but I take it that you want to be able to snap to a design profile at a specific point and it wont let you. This is because you can't, directly.
What you can do is find the station of the point that you want on the profile in question using the transparency commands and then once you have the station value, put that value into the inquiry tool located in the ribbon bar that pops up when you selct the profile in question. It will then provide you with the elevation at that point. You can then snap an object using the station and elevation transparent command. Its messy but its a workaround.
HTH
Active Contributor
Wilbers2013
Message 3 of 4 (180 Views)
10-09-2013 05:02 AM in reply to: Nik-D
Hi
What I want to displau a grid line at where the profile changes direction.  Like the red line on the image.  There is a option to switch on/off the grid line for a chane in the alignment direction.  I have drawn in the lines now.
___________________
ArcGIS 10.1
Nik-D
Message 4 of 4 (167 Views)
10-09-2013 06:23 AM in reply to: Wilbers2013
You can do it as follows:
Select the grade labels you want to extend to the edges of the profile graph. Edit the labels and enter the label style composer.
1. Add a LINE component to the label
2. Make the settings for the line as follows:
3. Exit and save the changes
4. Select the labels in the profile view and select properties (NOT LABEL PROPERTIES)
5. change the settings in the GENERAL settings as follows:
The label should now display as you want.
HTH
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
