Civil 3D Forum
Grid at Vertical Geometry Point
7 REPLIES 7
Message 1 of 8
Wilbers2013
2894 Views, 7 Replies
Is it possible to have a profile view grid line at a Profile Vertical Geometry point?
Willie Wilbers
AutoCAD & Civil 3D 2014
ArcGIS 10.1
7 REPLIES 7
Message 2 of 8
Nik-D
in reply to: Wilbers2013
I might be wrong but I take it that you want to be able to snap to a design profile at a specific point and it wont let you. This is because you can't, directly.
What you can do is find the station of the point that you want on the profile in question using the transparency commands and then once you have the station value, put that value into the inquiry tool located in the ribbon bar that pops up when you selct the profile in question. It will then provide you with the elevation at that point. You can then snap an object using the station and elevation transparent command. Its messy but its a workaround.
HTH
Message 3 of 8
Wilbers2013
in reply to: Nik-D
Hi
What I want to displau a grid line at where the profile changes direction.  Like the red line on the image.  There is a option to switch on/off the grid line for a chane in the alignment direction.  I have drawn in the lines now.
Willie Wilbers
ArcGIS 10.1
Message 4 of 8
Nik-D
You can do it as follows:
Select the grade labels you want to extend to the edges of the profile graph. Edit the labels and enter the label style composer.
1. Add a LINE component to the label
2. Make the settings for the line as follows:
3. Exit and save the changes
4. Select the labels in the profile view and select properties (NOT LABEL PROPERTIES)
5. change the settings in the GENERAL settings as follows:
The label should now display as you want.
HTH
Message 5 of 8
farhan.azmi
in reply to: Nik-D
Hi Nik, I just want to add grid at vertical geometry point:
at station 0+003.000 & at station 0+156.101.
Plz help me in this
Message 6 of 8
Nik-D
in reply to: farhan.azmi
Hi Farnhan I'm only seeing this message now. Did you find a solution or are you still looking?
Nik-D
Message 7 of 8
farhan.azmi
in reply to: Nik-D
No did not get any solution
Farhan Sheikh
Jeddah,Saudi Arbia
Mobile:+966-(0)-532091070
Message 8 of 8
nikoue
in reply to: Nik-D
This is really a good solution. But it has a problem. If you want to use a no continuous linetype you cannot set a linetype scale.
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
Rail Community
