I keep getting grey boxes that show up from nowhere when I plot. They do not show up on screen, there is nothing to select, all the layers are turned on, there are no old wipeout frames. When I straight plot, the show up in one place, when I plot to PDF, they show up in a different place. They do not show up on plot preview. I have run audit and purge. Please help before I go insane. Thanks.
Solved by Jay_B. Go to Solution.
Could be the NAVBAR, try turning the Navbar off, if on as it will plot even though it's a GUI element.
I have run into this problem before. I believe the ViewCube is the culprit. Go to "options", 3D Modeling tab, and then make sure all boxes are not selected under "Display the ViewCube"
My Co-worker has this issue. I don't.
My Co-worker has an NVIDIA video card. I have an AMD GeForce.
Can anyone with this issue confirm whether video card brand is a factor? Specifically, is your video card an NVIDIA?
Michael Partenheimer
