Civil 3D Forum
Grey boxes from nowhere
7 REPLIES 7
Message 1 of 8
413 Views, 7 Replies
I keep getting grey boxes that show up from nowhere when I plot.  They do not show up on screen, there is nothing to select, all the layers are turned on, there are no old wipeout frames.  When I straight plot, the show up in one place, when I plot to PDF, they show up in a different place.  They do not show up on plot preview.  I have run audit and purge.  Please help before I go insane.  Thanks.
7 REPLIES 7
Message 2 of 8
Can you post a copy of the drawing and PDF?
Message 3 of 8
Jay_B
Could be the NAVBAR, try turning the Navbar off, if on as it will plot even though it's a GUI element.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 8
in reply to: Jay_B
Thanks, that worked for the first one. I try it some more. But that is a
great start.
Timothy J. O'Connor
Engineering Technician
Geotech Computer & Tech Support Group
SOP/EAP Room Custodian
10th Fl, office #98
303-445-3066
Message 5 of 8
TylerT1987
I have run into this problem before.  I believe the ViewCube is the culprit.  Go to "options", 3D Modeling tab, and then make sure all boxes are not selected under "Display the ViewCube"
Message 6 of 8
Thank you, but the problem was solved. It was NAVBAR issue. I'm not sure
how it affects plotting/printing, but it does.
Timothy J. O'Connor
10th Fl, office #98
303-445-3066
Message 7 of 8
in reply to: TylerT1987
Thanks, but it was the NAVBAR. It had to be turned off. Not sure how that
affects plotting, but it worked.
Timothy J. O'Connor
10th Fl, office #98
303-445-3066
Message 8 of 8
Partenheimer
My Co-worker has this issue. I don't.
My Co-worker has an NVIDIA video card. I have an AMD GeForce.
Can anyone with this issue confirm whether video card brand is a factor? Specifically, is your video card an NVIDIA?
Michael Partenheimer
Rail Community
