Civil 3D Forum
Gravel Hatch
6 REPLIES 6
JeffCamarena
1489 Views, 6 Replies
Gravel Hatch
 I am drawing an area of cobblestone. I am using the gravel hatch pattern and scaling it up. Is there a way to have the hatch pattern close the circles of the gravel peices at the boundary? Or is there another hatch pattern that can do this?
6 REPLIES 6
Usually this is due to being too far away from the origin point.  If you move you model closer to 0,0 and then hatch it, it should look better.  Then you can move your model back to original place is you choose to.
Todd Rogers
troma
in reply to: ToddRogers-WPM
You don't have to move.  You can just set a hatch origin in the hatch edit dialog or ribbon area.
Mark Green
Working on Civil 3D in Canada
neilyj666
in reply to: troma
changing the hatch origin is definitely the way to go
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
JeffCamarena
in reply to: JeffCamarena
Thank you for the origin tip.
But, I what I am looking for is at the border/boundary of the hatch area, I would like full "circles" representing the gravel/cobblestone. Now, the gravel/cobblestone look as if a knife cut away the area beyond the boundary. I would like to have the hatch patern look as if someone layed the stones down in a square.
Mark_Castle
I don't think that would be possible with a hatch. You might have to draw a single stone at the proper size and then use the array command to get what you're after.
Mark Castle
Win 10 64-Bit, Thinkpad P50
16 GB RAM; Core i7-6820HQ; Quadro M1000M
Joe-Bouza
The best I can come up with is: over hatch and polyline clip the patter to show the whole cobble?
Your Name
Rail Community
