Civil 3D Forum
Gradual Change from One Assembly to the next - SAC
3 REPLIES 3
MarcDandy
497 Views, 3 Replies
I'm in the process of building a subassembly in SAC. My goal is to have it transition from one cross section to another over a set length (by using station values). I can set it up so that at a certain station it switches cross sections, but I need to have a gradual change.
I've looked at other posts on here, but they all relate to road cross sections and changing slope (at least from what I saw). Any insight as to the proper way to do this (maybe with Auxiliary points and links) would be greatly appreciated.
Marc
3 REPLIES 3
hmartinez5
in reply to: MarcDandy
Not quite sure what kinds of changes you want to make to your assembly but have you taken a look at this?
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Transitions-with-a-Sub-Assembly/m-p/4425639
MarcDandy
in reply to: hmartinez5
That sound's like exactly what I'm looking for, just I don't have SAC 2014 installed so I can't open the .skt file.
doni49
I'm in the same boat in that I've had many occasions in which I needed to transition between two assemblies over the course of a specified station range.
And it looks like I won't have access to C3D until the beginning of the year.  I'm on 2012 until my boss gets 2014 deployed.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Rail Community
