I'm in the process of building a subassembly in SAC. My goal is to have it transition from one cross section to another over a set length (by using station values). I can set it up so that at a certain station it switches cross sections, but I need to have a gradual change.
I've looked at other posts on here, but they all relate to road cross sections and changing slope (at least from what I saw). Any insight as to the proper way to do this (maybe with Auxiliary points and links) would be greatly appreciated.
Marc
Not quite sure what kinds of changes you want to make to your assembly but have you taken a look at this?
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Transitions-with-a-Sub-Assembly/m-p/4425639
That sound's like exactly what I'm looking for, just I don't have SAC 2014 installed so I can't open the .skt file.
@Anonymous wrote:That sound's like exactly what I'm looking for, just I don't have SAC 2014 installed so I can't open the .skt file.
I'm in the same boat in that I've had many occasions in which I needed to transition between two assemblies over the course of a specified station range.
And it looks like I won't have access to C3D until the beginning of the year. I'm on 2012 until my boss gets 2014 deployed.
Don Ireland
Engineering Design Technician
