Civil 3D Forum
Grading
5 REPLIES 5
DrWileFTracer
6131 Views, 5 Replies
Grading
I'm trying to create a proposed grade surface using the grading tools. I drew the outline boundaryof the proposed surface as a closed polyline then created a feature line from it and assigned different elevations to it. When I try to select the feature line in order to create the grading, I get "THIS FEATURE OVERLAPS ITSELF AND CANNOT BE GRADED". What could be a possible reason for this?
Thanks in advance
Wil
5 REPLIES 5
HansSMS
in reply to: DrWileFTracer
Can you post a drawing with the offending featureline?
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
Sounds like the polyline is not actually closed, that it is actually overlapping itself.
Todd Rogers
Joe-Bouza
Thanks in advance
Wil
Pseudo nodes is my guess. Do a map clean to get rid of them, better yet save a step and draw the FL directly
Joe Bouza
Map clean worked. Thanks very much.
Wil
Joe-Bouza
Please select "accept solution" so other readers may be aware of your solution
Joe Bouza
Rail Community
