I have problem to cut a volume from EG.
I want to cut out a volume between EG and a feature line under the surface.
And I want the slopes to be 90 degrees.
How do I do that?
And how do I calculate the volume from the cut area?
Please help me!!
When you say 90 degrees, do you mean vertical? Is your feature 'line' just a line, or is an enclosed shape at a particular elevation? You basically need to create 3 surfaces, EG, FG and a volume surface (which compares EG against FG). If you want the volume within a vertical sided space, the easiest is to find the 'bounded' volume (right click the volume surface in the prospector and select a boundary).
Yes, I mean vertical. The feature line is a closed line, who I lay on a specific elevation below EG.
I am kind of newbie in Civil 3D, so hope you can wright a list who I can follow.
OK no problem. I hope I don't leave out anything.
If you have any other questions, you should post your drawing so that it will be easier to explain.
Cheers
- Mick
Bear in mind that tin 's do not like vertical faces. Due to this we typically approximate vertical edges.
Another method is to take your feature line, create a stepped offset .05 or .1 units outside and assign elevations from the eg srf to the new fline. Place both of these in an FG srf and you now have two surfaces to compute volumes with.
John Mayo
I was figuring that you don't even need to put in the vertical (or near vertical) edges, since you can achieve the same thing way easier with a bounded volume.
Cheers
- Mick
Actually you don't even need to create a boundary. A surface to surface comparison will calculate at all x,y locations where both surfaces exist, and it will automatically form an edge anywhere one surface or the other is missing.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
So true Steve, but I think it is good practice to specify the boundary just so the user is fully aware of what is being reported.
Cheers
- Mick
I agree with you Matt. Sometimes you need a boundary (disconnected areas) most often you don't. Don't create it unless you need it.
I was just trying to provide some insight into the app for the OP. I also gave an alternative method not a preferred method. Bounded volumes are the correct tool IMO for this job but I'm betting the OP will get more work. 😉
John Mayo
Regarding specifying a boundary - I was really considering the needs of the learner. Also, being unsure of the geometry of the lower surface I still thought it was a good idea. Anyway, I agree, no use adding redundant geometry if you understand what's going on.
What happened to the OP anyway?
