Civil 3D Forum
Grading footprint
2 REPLIES 2
238 Views, 2 Replies
Grading footprint
I try to grade a simple polyline to a surface.
The slopes I am using are 2:1 for cut and fill.
The slopes should be ok for daylighting to the surface.
I receive a warning:
"Some of all of the footprint doesn't grade"
But the software just hangs up.
Is there an issue if the slopes do not work that the software hangs up?
In Civil Design came up with an error but didn't crash.
Any ideeas?
Florin
2 REPLIES 2
same thing happens to me. when i try grading a range of stations, not the whole polyline, sometimes it is ok, but it can't work for the whole polyline. I think it is a bug of the program
Terrain_IaPLS
We have been trying to perform what we call "simple" grading objects with CIVIL3D as well.
Just returning from the AU in Vegas, whole class on grading objects ended up to be a joke, in that being told the Civil 3D grading objects are still "unstable" and continue to use LDDT.
Go figure. We get mixed results, crashes, footprint not moving dynamically, you name it in Civil 3D full release.
Look at your slopes, maybe your missing (under/over) your surface definition your tieing to. Steepen, then work up/down to ensure your hitting your surface match.
Geoff T.
Xi Computer CM-MasterCase Pro 5 tower case (Win10 O.S.)
Ten Core i9-7900X @ 3.3/4.5GHz Sealed Water Cooled
w/ Asus PRIME X299-A mobo
32GB DDR4 @ 3600Mhz RAM
SSD Samsung 850 EVO H.D.
Nvidia Quadro P2000 (span2) + 2000
3 ViewSonic VG2436wm-LED displays
Rail Community
