Yes, what you describe is as designed.
1. Drape Feature Line on to surface.
2. Use Draped Feature Line to grade with.
3A. Crash
or
3B. Wait 30 minutes and the grading suddenly shows up.
or
3C. Give up before the crash and Ctr-AltDel yourself out of the Program.
You should get a warm fuzzy feeling knowing you are doing it right. LOL
Just know that there are only 50,000 gradings that are needed on any given
project and that it may get fixed in a future release. Not fixed in 2005,
2006, 2007, 2008, or 2009, but maybe in the future.
I now return to my request 3 years ago that we need to be able to grade a
single contour using the old LDD command for offsetting at Grade/Slope, etc.
If the new way worked, fine. But since it sucks, just add back in the tried
and true way to get the job done.
Believe it or not, getting work out the freakin' door is the most important
thing.
Tim
"neilw"
wrote in message
news:5993513@discussion.autodesk.com...
I made sure the feature line was weeded and had only the geometry vertices.
I was working in 2009. It took perhaps a minute or more for it to generate a
daylight footprint. On a couple of occasions it crashed C3D. Any edits to
the feature line were tedious due to the long update times. I just gave up.
"Tim Scott" wrote in message
news:5992941@discussion.autodesk.com...
If you are in 2008, you will probably crash trying to grade from a draped
Feature line. Those extra "round" vertices on the draped FL are not
completely compatible with all other features. Explode it to a 3dpoly, then
weed it, then use it to grade with which will create a new FL in it's place.
Even in 2009, Grading does not like FL's with a lot of vertices. It should
be called "Grading Lite" until it works correctly.
Tim
"neilw" wrote in message
news:5992947@discussion.autodesk.com...
I had very slow performance while doing exactly the same thing. I attribute
it to the many elevation points that get added to the feature line when it
is draped on EG. I never found a solution.
wrote in message news:5992829@discussion.autodesk.com...
I want to use a sImple grading, just 4:1 to existing ground from a feature
line that essentially follows the existing ground surface.
Civil 3D crashes anytime I try to create the grading. I am looking for
possible causes. Is there a limit to the number of elevation points on a
feature line used for grading? The feature line was created from an
alignment that had 30-50' radius curves also (3 total). Looking for ideas
on what is causing the crash.
