Civil 3D Forum
Grading Best way to add constant Grade between points
13 REPLIES 13
Message 1 of 14
ralstogj
2696 Views, 13 Replies
Hi
I work with featureline on grading alot and wanting to know if working in plan view is there a quick way to apply a contant grade between to point that span across other points. At the moment I always open elevation edit there must be a faster way?
Sugguestions
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
13 REPLIES 13
Message 2 of 14
ralstogj
in reply to: ralstogj
Just answered my own question
using the menu
Grading->Edit Featureline Elvations->Set Grade/slope between points command
Assign it to a button or shortcut key
Regards
Justin Ralston
Message 3 of 14
ericcollins6932
also flatten grade in the elev editor - I misunderstood flatten grade made it 0, but it makes it what you want...
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 4 of 14
Joe-Bouza
there is a button on the ribbon. when you grip a fl the ribbon defaults to it.
Joe Bouza
Message 5 of 14
ralstogj
Thanks Joe
I always forget those buttons are there as you have to turn them on ever time you start civil3d by pressing the buttons further along just another button click.
Regards
Justin Ralston
Message 6 of 14
I love the Ribbon. Smiley Wink Best thing sinse sliced bread
Message 7 of 14
Civil3DReminders
That's why I typically edit Feature Lines from the Modify Tab of the ribbon, all of the commands, none of the pain of expanding the panels.
Christopher
Message 8 of 14
Joe-Bouza
Not to mention if you grab the feature line first the ribbon goes there automatically. ...Hmmmm I guess I mentioned it.
Joe Bouza
Message 9 of 14
Jeff_M
in reply to: Joe-Bouza
No it doesn't Joe. As Justin noted, the first time you use it, the EditGeometry and EditElevation panels are hidden until you hit the 2 buttons.
Jeff_M, also a frequent Swamper
Message 10 of 14
Joe-Bouza
in reply to: Jeff_M
First time and then...
Yes I can see how that woul be a productivity killer Smiley Wink
Joe Bouza
Message 11 of 14
I used to have a command in toolpac for this...
Using the ribbon clicking icons is THE REAL PRODUCTIVITY KILLER
Unfortunatelly the toolpac command no longer works after I updated the tool. But however according to mister dotsoft nothing has changed while that and a load of other commands aren't working anymore. But... I can buy an upgrade ROFLOL and have no other option than to do so in order to get my old function back for wich I paid already.
ribbonstyle:
- convert 3d poly to featureline
- click like a moron like 8 times
commandlinestyle
- type 2 to 3 characters
- select 3dpoly
- hit spacebar 4 times (wich should of course be only one time)
Ribbon best invention since sliced bread for the elderly that like it slow.
The number of annoyances is skyhigh. In case a developper would sit a day next to me I could tell him all day long about commands that could be way better.
No I change a 3d poly to featureline. I want it in the same layer. Command switches back to it's default layer. I hoped to see featureline in the toolspace-settings and under that commands in order to tell the stupid program to use the last entry again but hey it aint there.
It's beyond believe how crappy this software is
Message 12 of 14
Aren't these the settings you are looking for? Other than the removal of the extra clicks.
You can create aliases of the commands on the ribbon for faster access, although it would be nice if Autodesk did provide the _CommandName options without a dialog box that most AutoCAD commands have that way the entire command could be put in a lisp command.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 13 of 14
thnx, that one saves some clicks at least 🙂
Message 14 of 14
Matthew3
in reply to: vandenoosterkamp
I use the command QUICKEDITFEATUREELEVS for grades and elevations.  Its in the ribbon.  Hover over the featureline segment, direct the triangle, click and type a grade.   I use the elevation editor mainly for review.
Rail Community
