I have a railway corridor with multiple baselines and regions and for some reason, I am getting 'ghost' sections showing up in various section views. Not every section within any range of stations, but intermittently. Labels are being inserted (incorrectly) but there is no ryhme or reason since the section that is showing as the 'ghost' shouldn't be there in the first place.
These have been created using C3D 2012 by a novice user (who had created alignments with similar names in different sites eg Site 1 may have an alignment named DITCH A-B-C and Site 2 would have an alignment named Ditch A-B-C) but the alignments are not the same.
Any help would be greatly appreciated.
Jeff, the issue is the ghost sections showing in track B that have the labels where they shouldn't be. Take a close look at the label placements for station 2+50 in the Track B sections. You will see labels are duplicated but in the wrong spot. This assembly should show in ALL sections up to 3+50 but it doesn't, even though the settings are the same for the entire section group.
There are line & text objects that look like they were labels at one time but have been exploded. Perhaps these are left over from a different Assembly, or the sectionviews shrunk but since the labels were exploded did not relocate themselves? I suggest deleting these as they are no longer dynamic to the sections or sectionviews. There are also some manually placed Offset/Elevation labels that appear to need relocating, but these were not placed automatically by C3D.
I am seeing 2 assemblies (for 2 baselines) for Track B stations 0+00 through 4+50. Although at 0+00 & 0+50 I can only tell there are 2 from the labels which show these 2 baselines to differ in elevation by 0.02.
Don Ireland
Engineering Design Technician
