Civil 3D Forum
Ghost Sections
3 REPLIES 3
sboon
332 Views, 3 Replies
Ghost Sections
I've just finished a design update and I'm ready to reprint the section sheets.  I opened the section views drawing which has the design xref'd into it and immediately noticed that I seem to have both the old and the newer sections in each view.  I have unloaded and reloaded the design drawing, and removed all of the sections from my sample line group except for the EG.  I am still seeing all three of the old surfaces plus the newer version of EG.  When I check the properties for an individual view it shows a list of sections that have been removed from the sample line group.
Has anyone else seen this?
Steve
Expert Elite Alumnus
3 REPLIES 3
apweng
in reply to: sboon
Hi Steve we had this happen all the time on SFPR when pulling section data through Xrefs.  It was a repeated effort of removing the section data from the sample lines entirely, and re-attaching.  Also if section view layout was edited, then the layout was re-calculated when the section data was re-attached to the sample lines.
Andrew
SethHall
in reply to: sboon
Does recreating the sample lines get rid of the "ghost" objects?
Seth Hall
Product Owner
Model Builder
LeafRiders
in reply to: SethHall
I think i've ran into a very similar issue. I have created a corridor surface and now deleted the surface and removed the sampling of it. Now i have the section views left behind and I can't blow them away (select similar) without selecting each of them manually, when you're dealing with 100 or so (x8 lanes), that's not practical. Thoughts anyone?
Rail Community
