I have the same problem. I couldn't find such a thing in label style composer - I assume it should be in the chainage offset label style composer. It shouldn't be a problem for autodesk, to run this functionality - is it possible to make a hotfix or any service pack?
Interesting... You can add the Instantaneous Direction to a Station/Offset label, but not the Instantaneous Radius. And I can't find Instantaneous Radius in any of the Reports or in the Inquiry Tool, either.
It's available, as the attached image from the DisplayAlignProf command in the Sincpac-C3D show that the value is available internally. But I haven't yet found any way to get it with C3D's built-in commands...
Hi, check this out. Andrew.
