Civil 3D Forum
Get radius value from clothoid at exact station along an Alignment
3 REPLIES 3
nbokhammar
1007 Views, 3 Replies
Is there a way to find out what radius value a clothoid have at an exact station along the Alignment?
3 REPLIES 3
I have the same problem. I couldn't find such a thing in label style composer - I assume it should be in the chainage offset label style composer. It shouldn't be a problem for autodesk, to run this functionality - is it possible to make a hotfix or any service pack?
Sinc
in reply to: MaciejKrynski8090
Interesting...  You can add the Instantaneous Direction to a Station/Offset label, but not the Instantaneous Radius.  And I can't find Instantaneous Radius in any of the Reports or in the Inquiry Tool, either.
It's available, as the attached image from the DisplayAlignProf command in the Sincpac-C3D show that the value is available internally.  But I haven't yet found any way to get it with C3D's built-in commands...
1056i947AC25CDF1CE897
Sinc
dnl999
in reply to: nbokhammar
Rail Community
