Civil 3D Forum
Get data from AC3D (tables) to Excel // Get tables of Cant Tabular Editor
4 REPLIES 4
ascensojimer
689 Views, 4 Replies
Good evening,
I want to export data from AC3D to Excel; I've tried to do it with copying directly the tables I made, but it isn't text or number format.
For example, I want to get the data from this table:
Do you know about some macros or procedures that can help me?
I know that with previous versions of autocad it could be done.
In addition, I also want to get value table of the calculated cant of the "Cant Tabular Editor":
How can I get a table of this data? I need it because I have a lot of curves and I want to do some verifications of the standars of my country.
Any help would be highly valued
Thank you in advance,
4 REPLIES 4
Jay_B
in reply to: ascensojimer
For the "Cant Tabular Editor".
Right click on the Cant Tabular Editor as shown in caption (anywhere one cell/line is fine)_copy to clipboard_open excel_paste.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
troma
For the C3D table, I think I've seen discussions on this before.  If I remember rightly, the only solution was to explode to lines & text, then use a lisp to export it as a .csv.  Not very pretty, I know.
Mark Green
Working on Civil 3D in Canada
MikeEvansUK
Or create the table to form a CSV file format.
So..
Easting,Northing,Elevation,Definition,Values,Values,Values;;
Use the ;; at the line end to indentify it later.
Explode to text then use TxT2Mtxt command and select the text objects.
Edit add hard returns where ;; are, copy and paste to notepad and save as a csv file. Open and edit in excel.
Lot of work but does work.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
ascensojimer
in reply to: Jay_B
Thank you very much!! I hadn't expected that it would be so easy!
With the table I can do the same as the cant tabular editor (because there already exist a table editor as well as cant editor).
Rail Community
