I am new to the board, and was wondering if there was any way to get deflection angles of an alignment into a table? I finally figured out how to get C3D to label them using the add note label. If this is not possible, is there a way to make a table of the notes? I am using C3D 2013 version if it makes any difference.
Thanks in advance for all help.
Properties for "pi included angle" or "delta angle" can be set in the Table Style. (see attached delta example)
To create the tables, first create line and segment labels for the alignment.
Create a curve label expression with this code:
{End Direction}-{Start Direction}
Be sure to set the Format result as: to Angle
Reference that expression as one of the columns in the curve table. Set the Format to DDMMSS in the table style when you add this expression as a column component.
I would like to have a deflection angle in the alignment table aswell. However, I would like to do this without curves.
I need just a deflection angle of the PIs. Any pointers?
Thanks. Trudi
