Civil 3D Forum
Get a list of Available Point numbers
16 REPLIES 16
Message 1 of 17
AllenJessup
1687 Views, 16 Replies
I just had an internal request for this and I had to look it up. So I'll share what I found and have a place to find it myself next time.
One way to do it is to select a COGO point to bring up the COGO Point Contextual menu tab. In COGO Point Tools you can select List Available Point Numbers.
The method I prefer is to simply type LISTAVAILABLEPOINTNUMBERS or LISTUSEDPOINTNUMBERS at the command line.
Allen Jessup
CAD Manager - Designer
16 REPLIES 16
Message 2 of 17
AllenJessup
in reply to: AllenJessup
Just wanted to add. Those commands can be set up as Aliases. So you don't have to type in the whole command each time.
Allen Jessup
Message 3 of 17
AllenJessup
Oh. You might also like the NEXTPT command. It will allow you to see both a Free and Used point list and set the next point #.
Allen Jessup
Message 4 of 17
Joe-Bouza
Hi Allen
My system does not identify NEXTPT. how did you find it?
hnnn? I no longer have an option to embed an image in the post. Did they take that away?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 5 of 17
troma
in reply to: Joe-Bouza
Allen, do you have a third party app for that command?  Or is it newer than 2011 maybe?
Command: nextpt Unknown command "NEXTPT".  Press F1 for help.
No embedded image option here either.
Mark Green
Working on Civil 3D in Canada
Message 6 of 17
AllenJessup
in reply to: troma
I have a couple of 3rd party apps running in 2012. I'll have to check it out. Most 3rd party command line start with an identifying character. I don't see that but I'll check their help files. I don't remember how I found it. I was adding the previously discussed command to my notes and noticed that one.
Autofill completes it, if that means anything.
Looks like I can insert an image.
Allen Jessup
Message 7 of 17
troma
Maybe it's going to be an Elite privilege only?
Mark Green
Message 8 of 17
AllenJessup
in reply to: troma
OK. I found it. It is a 3rd party app, Sincpac. However they also have separate ones for used and free points. Since I found that there are command line equivalent in Civil Maybe I'll find and equivalent of that too. Using the commands above. It wouldn't be too difficult to write a routine to duplicate it.
Allen Jessup
Message 9 of 17
troma
With regard to the images:
http://forums.autodesk.com/t5/Autodesk-Discussion-Groups/Why-we-are-not-able-to-insert-in-text-image...
Mark Green
Message 10 of 17
Joe-Bouza
in reply to: troma
interesting? Some have it and some don't
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 11 of 17
dgordon
Allen,
Can I ask how you get the picture in the body of the post instead of as an attachment at the bottom as a link.
I know I did this once or twice but can't remember what I did.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 12 of 17
AllenJessup
in reply to: dgordon
Follow the link posted by troma in message 9. This will explain the current problems they're having. I may be able to insert the picture at the moment because of my EE status.
Allen
Allen Jessup
Message 13 of 17
Joe-Bouza
As per troma's thread: they did away with it
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 14 of 17
AllenJessup
Joe. I don't quite read it like that. I'd say - they did away with it by accident. The last message said "This issue has been identified and we are working on a fix." That seems to mean they plan on reinstating it if possible.
Allen Jessup
Message 15 of 17
Joe-Bouza
Agreed: I could type all that Smiley Wink
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 16 of 17
Hi all,
Allen is correct his EE role is letting him post within the text
We have identified the issues and it will be restored to everyone as quickly as possible.
Discussion_Admin
Message 17 of 17
The insert image into text issue has been resolved.
Thanks for your patience
Discussion_Admin
Rail Community
