We are pleased to announce the release of Geotechnical Module v1 for both Civil 3D 2013 and Infrastructure Design Suite 2014.
These are now available for download on Subscription Center along with release notes. Please uninstall any previous version of the Geotechnical Module prior to installing Geotechnical Module v1.
Thank you!
Uninstalled the previous version . . but getting the error message:
On Civil3d 2013.
- solved, the installation pack here is for version 2014 only, and not as described in the email I recieved:
My apologies for not clarifying the specific locations in my initial email.
The 2014 version of Geotechnical Module is avaialable to Infrastructure Design Suite Premium and Ultimate Customers on Subscription Center. Choose to "View all available Product Enhancements" and you will see the Geotechnical Module listed. Once you click on that link, you will see the download for v1.
The 2013 version of Geotechncial Module is avaialable to Civil 3D 2013 Customers on Subscription Center. Choose "Productivity Tools for AutoCAD Civil 3D 2013" and you will see the Geotechnical Module listed on that page with the download links.
Please let me know if you have any further questions.
The Geotechnial Module is no longer working....the popup say it has been succesfully loaded but when the import button is clicked...
Command: KYN_ImportAGS Unknown command "KYN_IMPORTAGS". Press F1 for help.
The only change (apart from standard Windows updates) is that I have installed the CodeExecutionVulnerability Hotfix .
I have uninstalled and reinstalled the Geotech module but it still doesn't work
Any suggestions?
neilyj (No connection with Autodesk other than using the products in the real world)
Hurrah - just had a long support call to try and sort out this geotechnical module and it is working again
Not sure why it wasn't working but the solution was to uninstall the module and delete the folder C:\ProgramData\Keynetix\AutodeskGeotechnicalModule, reinstalled and worked just fine
Kudos to GaryMorin8439 @ Keynetix for the help
Thanks for this post!
I just wanted folks to know that there is no need to uninstall and reinstall the module. Simply Deleting the C:\ProgramData\Keynetix\AutodeskGeotechnicalModule folder will allow the module to work. Civil 3D will remake this folder upon restart of the module.
Hi There is a need to uninstall the application. I think following are the steps which I recommend for Geotechncial Module install issues with Unknown Command Errors.
Cheers..
Prasad Pandit
Technical Account Manager
Enterprise & Goverment
AutoCAD Message:
SQL Compact Edition has not been detected, please install the drivers for SQL Compact Edition 4.0.
Where can I download Geotechnical Module and Bridge Module for Civil 3d 2015??
The one I found at Subscription Center is only for 2014 and 2013 versions...
I downloaded it here.
http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=23493689
But I get this error message when I try to import data ( I want to import CSV data).
Command "KYN_ImportAGS"
Any ideas?
Cheers
Can you look in the About Box and let me know exactly which version you are currently using?
Thanks!
--Jessica Tarr
Product Manager
Hi Jessica
The Geotechnics version is 1.16.0.2.
The command now works, but I have lost the ribbon. I have uninstalled and reinstalled and still no ribbon. Where do I find the partial cuix to load?
Cheers
when i try to uninstall geotechnical module civil 3d 2014 thru control panel, it is giving error 2343. i am trying to uninstall all autodesk programs so that i can install the revit 2015
hello!
anybody know if this module is still available, I have a Customer to ask about this one,
thanks in advance.
Simon Noyola
Down to Earth Technolgies, inc
Attached I have a sceenshot taken from my autodesk account. Please note that I do not have the option to download the Geotechnical Module "Enhancements". Please advise me on how can I download the geotechnical module for autocad civil 3d 2013 and 2016?
Much Thanks,
Alex
