AutoCAD Civil 3D General
New Member
Message 1 of 7 (282 Views)
Generating setting out (stakeout) points from an alignment or surface
282 Views, 6 Replies
08-13-2013 04:44 AM
Hi
Does anyone know how would I go about generating labelled points with xyz values at 5m intervals along a road alignment in Civils 3D 2014?
I have had a go with the AddAlignLabels command but could not figure out how to add an elevation value to the label. Also this method seems to require manual input for each label which is not practical as I will have have around 450 points to set out.
I have looked into the Stakeout Alignment Report, but this seems to require a survey database, which I don't have.
Surely this must be possible, I would have thought it would be fairly simple to do.
Any suggestions appreciated.
Max
*Expert Elite*
Jay_B
Message 2 of 7 (263 Views)
Re: Generating setting out (stakeout) points from an alignment or surface
08-13-2013 05:42 AM in reply to: HOP-Civils-Team
If you have an Existing Ground and Finished Ground profile the Profile "Incremental Station Elevation Difference Report" can quickly create what your looking for. There will be a few columns to delete but X,Y,Z for the specified stationing interval along alignment will be included. Note the output file type can be changed by clicking on the "save report to" folder.
Jay
C3D 2012 SP3 & C3D 2014 SP1
Win 7 Professional 64 Bit
New Member
Message 3 of 7 (253 Views)
08-13-2013 05:59 AM in reply to: Jay_B
Thanks for the suggestion, I'll give it a go.
*Expert Elite*
wfberry
Message 4 of 7 (242 Views)
08-13-2013 07:58 AM in reply to: HOP-Civils-Team
I am not sure exactly what you are doing with the 5m intervals.  If using an RTK GPS instrument, load the data collector with the SURFACE (Tin) and stake to the Tin.  Any where you set the rod down will give you a cut or fill.
Bill
Active Member
Message 5 of 7 (186 Views)
12-03-2013 08:41 AM in reply to: HOP-Civils-Team
I'm trying to do the same thing as HOP-Civils-Team but I don't have a surface.  I'm going to take the grade shots AFTER I stakeout the trail but I need an easy way to generate points for my alignmnet first.
Distinguished Contributor
Message 6 of 7 (177 Views)
12-03-2013 12:08 PM in reply to: HOP-Civils-Team
Your going about this the wrong way...unless your trying to satisfy some outdated agency or contract requirement. If you have an alignment and a profile in Civil3d just export the data to a landxml file, upload it to your data collector and you have everything you need to stake any part of the 'road'. This assumes everything is built correctly in Civil3d. We do a lot of road staking and never ever generate stakeout points. If you must create points you will need to use the create points from corridor option. While this option requires many other facets of your project to be setup properly, it does allow you to create points at elevation at almost any point imaginable.
Active Member
Message 7 of 7 (162 Views)
12-04-2013 06:52 AM in reply to: mikehathaway2942
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
