In 2009 our survey field books contained line commands like BEG (for begin a line) or RECALL or CLOSE to connect line work. Now it appears in 2011 the line work is generated by description codes ("EP B" to begin a line of edge of pavement ) or ("EP R2005 to connect our edge of pavement to shot 2005. Is there a method by which surveyors can code things in a field book to work in both 2009 and 2011.
Mark G.
Surveyor
We haven't changed the way that fieldbooks are imported, but we've added another way of doing linework from a text file. Your crew's shouldn't have to change the way they code a fieldbook, but you might want to look at the new options that we've introduced with the text file import including the "1 point curve" and in 2012 the "2 point curve"
Cheers,
Peter Funk
Autodesk, Inc.
