Civil 3D Forum
General Note - Plot Style of Leader
4 REPLIES 4
pcchenard
394 Views, 4 Replies
We use STB plot style tables for all of our drawings.  I have several general note styles setup in Civil 3D 2012.  When you pull the note text out so that you have a leader, the leader does not plot per the plot style assigned to the layer that the note is set to display on on the General tab.  It appears as the proper color and freezes with the layer properly, but it plots with the settings of the plot style assigned to layer 0.  Is there a reason that the leaders don't use the plot style setting form the layer it is displayed on????
4 REPLIES 4
sjg
in reply to: pcchenard
Did you check the leader settings, under the dragged state tab
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
pcchenard
in reply to: sjg
Yes, I did.  Everything on that tab is set to BYLAER.  There is no setting for PlotStyle anywhere in the note sytle settings.
AlmasSuljevic
Do you see the same issue if you plot to some other plotter? Does it show correctly on plot preview? How about other drawings-do they plot OK with that STB file.
In Plot dialog, is "Plot with Plot Styles" checked?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
pcchenard
in reply to: AlmasSuljevic
Yes, I see the same issue regardless which plotter I use.
No, it does not show correctly in the plot preview.
Yes, "Plot with Plot Styles" is checked in the plot dialogue.
Rail Community
