I was wondering where can I find the command to globally scale blocks by selecting them and it scales each block around its insertion point.
Solved by Murph_Map. Go to Solution.
The BEDIT command will globally scale / redefine a single block definition.
Select them either by picking on them or use quick select then change the x,y scale value in the property palette is what I use.
