Civil 3D Forum
GEOTECHNICAL MODULE
2 REPLIES 2
petelien
297 Views, 2 Replies
GEOTECHNICAL MODULE
Hi, i have imported my two geol and hole .csv files, and when they com into autocad, they are not to scale. i distance between holes should be 200 ft but when i measure using the distance command it is coming out at 70 ft. is there something I need to do before importing them in?
I have tried setting the coordinate system to the dwg, but that didn't help. I am using civil 3d 2014.
2 REPLIES 2
neilyj666
in reply to: petelien
Are you starting from the correct template? Are your UNITS set correctly
Can you post the geol and hole files?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
petelien
in reply to: neilyj666
I cannot post those files at this time. and my units are set to architectural. I also notice the northing easting points are off in this dwg. They do not line up in the right location. The northing eastings came from Arc Map. They are in FT, I am not sure what setting or units to check to make sure they are coming over in ft. Or would it be easier to change feet to meters in the excel sheet?
Rail Community
