When capturing an image from Bing using the GEOMAPIMAGE command, where is the image saved? I can't see it in the Xref manager.
Where is it?
Cheers
Solved by mathewkol. Go to Solution.
It's not an XREF, it is saved in the DWG. Look at your file size before and after you've captured the image.
Thanks Matt. That is what I suspected, but I hadn't looked at the file size, but yes it does jump up in size.
