Using GENIO import to import Bentley/MX topo data which has many strings of "Fewer than 2 Points" i.e. Spot Levels and Civil 3D then typically crashes.
A section of the data is shown above, my workaround is to find and replace 080,L with 080,P (which is MX code for spot levels i.e. C3D Points) and then Import, but it's difficult to know if all these single "point" strings are accounted for without several runs through the GENIO importer.
Anyone suggest a better way?
neilyj (No connection with Autodesk other than using the products in the real world)
How about posting your data file for those that might need it for testing?
My workaround didn't work and just crashed Civil 3D - there were also other strings with fewer than 2 points
Original GENIO data file attached if anyone else fancies a look at it
